Throttle Only Control??
Storapa
95
12
55
Warwickshire
Hi Folks,
Apologies in advance if this is a dumb question.
Is it possible to run the Q100H motor with only a throttle, I.e. no PAS or speed sensor.
Cheers,
Storapa
trex
7,703
2,671
yes. The bike is more responsive too.
Storapa
95
12
55
Warwickshire
Brilliant.
Any recommendations on the controller? I was going to use the. S06S. Will this still be suitable?
As a motorcyclist, I feel that a simple throttle will feel more natural.
Alan Quay
2,351
1,076
Devon
BMS recommend the S06 (s or p), which will make it run at 15 amps. You could probably modify the controller a little for a few extra amps.
The next step up is the S09 , which IIRC is about 20 - 22a. That may be too much, but others will be better placed to comment on that.
If you are average weight/fitness and don't have monstrous hills, you should find 15amps about right.
I don't believe that a Q100 will work with a S09P. They're sensorless, and Q100s don't run very well sensorless.
Storapa. Get a pedal sensor even if you think you wont use it. They only cost 60p, and you'll probably find that you prefer it to the throttle.
S06S should work well.
jhruk
318
68
A word of warning – it seems the S06S does not work with all variants of the Q100 motor.
I recently purchased a Q100CST (328) with the intention of using it with the S06S. However, when bench testing it I found it would not run properly with this controller. It was ok at slow speed but at higher speeds it ran very roughly, sometimes stopping. It seemed to be a timing problem.
I then tried the motor with a KU65 and a S12S, both were fine.
As I don't have another Q100 motor also I tried the S06S with a 328 Q85 and that appeared to be fine as well. I've no explanation.
I've got another problem with this motor now, but I'll save that for another thread.
I found the same with a S06P and a 328 rpm Q100CST. The KU65 works with the 328 rpm Q100s.
