Throttle location Help
Cam3roon2k41999
120
Hi, I got angry with my controller yesterday and pulled the connectors off
Does anyone know we're the location is of the throttle I took the outside casing off the controller and seen TS on one of the pins on the PCB is that throttle signal
8,518
From past memory having looked at a KT pcb yes, the pcb i looked at also had a White wire wired on the reverse side.
