Hi
I've got a Wisper 90SE which I've had for a year now and is therefore out of warranty.
I've had no end of problems with this bike and over this time have had a new control box, new battery and new rear wheel fitted, plus intermittent problems with the hi-lo switch (solved by drying it out and covering the switch in a freezer bag!). I'm pretty fed up with the bike to be honest.
My latest issue is that the twist grip throttle only seems to deliver just enough power to turn the rear wheel when the wheel is lifted off the ground. I've checked that the connection to the control box isn't loose but other than that I'm not not sure what could be causing it. Any ideas ?
As an aside how do people water protect the control box and all the associated wiring from water ? I was quite amazed that the design off the 905SE allows water and mud in to the compartment in which the control box is housed, via a nice large whole at the front. Is it best to seal this up ?
