Throttle control help
Brelades
16
Hi. I seem to have lost the written part of my post.
I want to connect a three wire throttle control to the box under the rear mounted battery of my Avocet Viking folding bike, the one without suspension. The box has three unused connectors. One with three wires as shown which I hope is the one to use, one with four holes on a thick white cable, and one with two contacts.
Sorry yhis is not a follow on from my earlier post, but I hope those knowledgeable members who kindly replied before can put me straight this time.
trex
7,703
2,671
the connector for your throttle is this 3-pin:
Brelades
16
Thank you, Trex. Fitted and working, but the lead from the controller is designed for a cross bar, and my wife has a folder so I will need to insert some extra wire. I wonder if you can suggest the type of wire, 3 core but quite thin, and also reccomend the type of joiners most suitable. I can get to Maplins tomorrow !
8,841
Most throttles and pas are 3 pin/3 wire and all tend to use black/red/ and any other colour for signal.
For wire you could use 1mm servo wire as the most volts it will have to carry is 5v, To join wire lengths and make water tight solder together and heat shrink.
