Since the electric motor touched the brake part, I could not put it back and therefore I did not install those parts. I'm posting some more photos now. I hope this helps you understand the situation. I didn't break anything. I'm still trying to install this. When I put the wheel in its housing, I did not tighten the screws as the engine was touching the brake.Speaking only for myself, I am unclear as to what you have for a problem!
I see that the axle fixing nut and washers are missing or appear to be either broken, or parts are removed or have fallen off, but the parts (disk/brake) you circled, are too unclear for anything better than guessing.
But having the axle not properly mounted and fixed in place, could cause severe problems with the disk brake....
May I suggest more photos from front, rear and sides. Maybe closer up, and your own description to accompany those photos.
Did you yourself remove the axle fixings, or have they just fallen off?
I personally see the problems to be from the area I have circled in black.....
But hView attachment 42769opefully, one of our pros here can assist you far better than I can.
regards
Andy
Insert an extra washer between the collar and the motor in the position shown by the red arrow below:
yes, as our friend said, I added a new one, it worked, but now the brake is stuck on the disc. When I checked the setting, I saw that it stood farthest from the disk. so it looks like I'll need a new disc and brake caliper.Hi, I think you have 2 choices...
Like @flecc says, I use the thinnest washer I can that will give me clearance. Best to loosen your brake caliper bolts before fitting the wheel as adding a washer will move the disk sideways - I always end up having to adjust the brakes after I've converted a bike to electric.
Or a brake upgrade as @davell - you will need a larger disk and a new mounting to move the caliper away from the hub. Both are good solutions, the washer is a cheaper option
180mm is normally the minimum size rotor for a rear hub- motor, then you should always start your alignment from the left (brake) side. Your first task is to arrange washers and spacers to get the disc lined up with the centr of the caliper. For just about every motor I've fitted, that required one additional standard 12mm washer on the axle closest to the motor.
There's no 12mm washer on the axle closest to the motor, which is what I said you should do!View attachment 42781View attachment 42782
I tried to do as you said but I couldn't quite understand. I don't understand where I went wrong. As you can see in the photos, the brake caliper still touches the electric motor.
I understand. I don't have now but i will buy 12 mm washer. my rotor size is 140 mm.There's no 12mm washer on the axle closest to the motor, which is what I said you should do!
What size rotor do you have?
Probably my rotor is small for this motor?Did you fix the rotor to the motor?
The rotor needs to stand further out from the motor. You could achieve this by placing washers on the fixing screws between the disc and the motor
Should I understand that I should buy a 180mm rotor as our friend said?Did you fix the rotor to the motor?
you need 160mm rotor.my rotor size is 140 mm.
