Part one.
September 11th 2009
Owners who prefer to abide by the instructions supplied with their machines, particularly the bit that says "Do not ride your E-bike on uneven ground" may choose to give this ride a miss...and I don't blame you!. I also suggest you choose a day when it hasn't rained for at least three days previously.
Section one of the "Oldest road in Britain".
A good start and finish point for this ride would be Coate Water Country Park in the southwest corner of Swindon, just a couple of miles from J15 on the micky four and the A419 from the North. There's room for around 150 cars in the free car park with toilet facilities and a decent cup o' tea for a quid...never plucked up the courage to try the burgers though!. My start and finish is over four miles away on the North side of Swindon. Follow the dotted line to join NCN Route 45 which runs along the top side of the lake.
Follow the signs for R45 up and over the M4 using the curly whirly footbridge, follow the "Timberland Trail" and then a short but savagely steep incline leads up to Chisledon. Storm water cascading down this hill has long since washed away any fine material, leaving a cobbled surface that will shake your eyeballs out.
Looking back, just beyond the red triangle in the hedge the ground just disappears down to the level of Swindon in the background.
The machine went up this slope in 2nd gear, but the 255 rpm Bafang was well below it's power band towards the top and gave little assistance. It's not just a question of pounding the pedals, but also picking a route through the mini boulders sticking out everywhere. I have often seen "roadies" walking their bikes up rather than damage their wheels. This is the only really steep hill on the route, the remainder of the climb up to the highest point is mostly achieved in 5th of 6 gears....occasionally dropping into 4th to keep the motor "on-song".
Both bum and bike welcomed a short length of road riding up through the village of Chiseldon to this junction.
Turn left if you fancy having a go at the Marlborough run, straight on for HGV MoT testing station ??. Today, I'm hanging a right and heading West on the tarmac section of the Ridgeway for a quarter mile. At a sharp left-hand bend the original Ridgeway Route continues straight ahead. Still on smooth tarmac, but only until the last cottage when the track changes to deeply pot-holed compacted earth. It's wide enough to accommodate the huge combine harvesters accessing the fields along the route. If you ride this way during harvest time, please give them all the room they need....it's a make or break time of year for the farmers. The surface then changes to the local authorities interpretation of a safe rural cycle route..ROAD PLANINGS, This is the dirty black dusty product of those rotary scarifiers used to prepare roads for re-sufacing. Having a very low cementitious value, it is the least most suitable material for rural cycle routes...you can roll it 'till the cows come home....it will never compact in the same way as limestone scalpings.
At one point, it looked as if the track was a little smoother on the other side, even as I started moving across the loose stuff in the centre of the track, I realised it wasn't the best decision I'd made in my life....It was like riding through a bed of marbles!!. A little further on the surface was much better, allowing the speed to come up to a steady 15 mph in 5th gear.
To be continued...............................
September 11th 2009
