The mysteries of balance wire connections
Mr Harry Morris
Jun 23, 2021
Hello everyone, a new boy to the forum so be gentle with me ! I have built a 36 volt lithium ion battery using the tried and tested 18650 cells and the solderless Vrusend kit, I also obtained a B M S of suitable voltage and amps and here is where I have come unstuck.
Those Phase wires ! I must admit that having watched various videos on How To Wire A B M S, I feel most uncomfortable when soldering the wires to ( what I believe ) are the correct cells I just don’t feel I’ve got it right.
Without connecting the battery to my eBike the B M S started to get hot so I immediately pulled the multi plug off and let things cool down ! I know the very first Black wire goes to the battery Negative but the sequence after that I find confusing ! The next wire after the Black is Red which is then followed by a Yellow wire and then another Red and so on.
I am pleased with the battery and it shows 42 volts and works very well on my ebike with the B M S disconnected, the battery is made up of 30 cells with 3 cells across, well that’s my rant over and I would be very grateful to anyone who could help with my confusion ! Cheers everyone Harry Morris.
8,533
The small BMS wires to the battery are sense wires used for balancing when charging.
The small Black as you say goes to Battery - or 0v this side of the pack is the even cell count so next connections on this side will be group 2, 4 , 6, 8 & 10 the final + cell.
The next wire is the 1st v+ wire (Red is odd count) so goes to cell positive #1 on the other side of the battery, it is usually soldered to the interconnector between cell +1 /-1. Use your meter to confirm the voltage is max 4.2v, next one (Yellow even count) goes on the other side to cell + #2. Again use your meter to confirm voltage is max 8.4v.
You find odd cell wires (Red) are on one side of the pack and evens (Yellow ) on the opp side.
So your Red wires are cells 1, 3, 5, 7 & 9.
Yellows are 2, 4, 6, 8 & 10.
Use your meter to confirm each voltage before connecting the wires.
3,993
It's best to show a picture of your actual BMS because there are several complications in the way that you connect the different types.
