I converted a mid range hybrid a couple of years back with a Cyclotricity rear wheel kit and 36v/11aH rack battery. The bike runs fine, but is just about unusable when the battery is dead as it's simply too heavy. All the weight at the back isn't good either. Just found out that the rack battery and the rear wheel weighs a hefty10kg (probably not including the rack itself)
I am about to convert a decent light hybrid and want the lightest solution with smallest amount of assist possible (10-15 miles or so). I see the https://www.cytronex.com/ front hub setup and small battery coming in at 3.6kg which is significantly lighter, but over £1000 for the conversion. Are there any similar products but slightly cheaper? Happy to have a front wheel drive or mid drive.
I see this company at approx £700, but not available to buy yet. https://www.lightest.bike/SHOP/Lightest-250W-kit-with-battery-presales-p221067532
