My Tern Link D8 folder, which I have used regularly and enjoyably for short-distance commuting and leisure purposes since purchase last summer, seems to be an ideal candidate for my first conversion project. My priorities for the project are threefold - it should be reasonably lightweight for a small e-bike, adding no more than 5 kg to the 12 kg of the standard D8; it needs strong and reliable hill-climbing performance to cope with the demanding moorland terrain here in East Lancashire; and finally it should not compromise the functionality and compactness of the folding mechanism.
My preference would be for a front-mounted hub motor, partly because of the ease of fitment (and removal if necessary) - the D8 already has steel forks with about 78 mm clearance between dropouts. A light, compact 250W motor kit for a 20 inch wheel (at 328 rpm) should be powerful enough for my purposes, such as the Q85:
http://www.bmsbattery.com/ebike-kits/421-250w350w-q-85100sx-motor-e-bike-kit.html
I haven`t yet decided on the battery placement, but the two most straightforward options are to use either the water bottle mounts forward of the main frame hinge or the Biologic rear carrier rack.
Any suggestions from members experienced in the arts of converting small folding bikes would be much appreciated, and it would be good to hear from fellow Tern enthusiasts with similar plans, too.
Kind regards,
mrail1982
Kind regards,
mrail1982
