Techical Assistance with Wuxing H T-268 Electric Bike
JW1980
13
Hello, I recently joined your site in search if some help with his nee purchase ai have made. I posted last week in the new to the site forum and got some great answers - thank you.
As my questions are of a technical nature, I thought ainwould post here too. Hope thats ok.
Please let me explain.
I am not an actual owner but my bother has been for many years. He has been using several older model PowaBykes to get around due to mobility problems.
As an engineer, I have been looking after an maintaining them for him, having gained a wealth of information from the PowaByke website.
Recently an opportunity arose to purchase second hand something quite different for my brother. This is, I believe called a Wuxing H T-268. It is modelled more to look like petrol powered moped.
Of course I have quickly discovered there is a huge difference between the powabyke and this one and feel I need a little help. My brother has found it is slower and does not have the same range as his old bike even though this has new batteries in it.
I have looked on line but can't find an actual website for the bike. I did find a couple of links to suppliers and have emailed them but had no answers.
I am hoping someone here has some expert knowledge on this bike. If you do, please help !
Specifically I was initially wondering the following:-
+ What should the maximum speed be and can it be adjusted ? I know the weight it is carrying will have a bearing on this.
+ What should the range be like in miles ? Like above I know the weight makes a difference.
+ The batteries are lead acid. As an engineer I would say these need to be fully charged and discharged every time but I have read on some site they should be topped up as often as possible. Is that true?
+ Does anyone have or know where I could source a user manual and a service / technical manual like on the PowaByke website?
Thanks in advance.
Jonathan
Alan Quay
2,351
1,076
Devon
As d8veh said in the other thread, SLA's will last longer if you give them an easier time of it. This means a lower discharge and then recharge is best, just like the battery in your car.
But that said, they won't last very long and are usually a false economy. 200 cycles is often quoted. Compare that with lithium-ion, typically 800 cycles, and greater energy density.
JW1980
13
Hi Mike Higgins / All,
Thank you for your response and sorry for the delayed reply.
Yes d8veh gave some good advise on the battery.
I was more wondering if someone was able to help me with my other questions :-
I would really like if possible to get hold of the original specifications, so I can check the batteties fitted are of the correct specification.
Thanks in advance.
Kind regards
Jonathan
You were supposed to tell us the battery designation.
JW1980
13
Hi d8veh,
Yes, sorry but I have not been to my brothers to take a look. Have had a lot on at work.
I think though that the battery questions have been answered now.
I was windering if anyone could help with my other questions :-
Kind regards
Jonathan
