I have a Swytch Air (mk3) set up with the LCD controller connected to a XieTong Q100C CST 36V 350W rear hub motor. This is my second “hybrid” set up for a Mezzo folding bike and the first one (similar hub, think it’s an Q128?) works with no problems.
This new build is showing some strange issues. I’d be hugely grateful if anyone on this forum can give me a steer as to what to do/try.
When everything is connected up and I use the throttle to just test that the motor gets power and runs in the right direction, it works, but the throttle doesn’t seem to ramp up power smoothly (I get the impression it’s pretty much all or nothing - but that could be me looking at the wheel spinning and not being able to tell), and the controller goes straight from indicating 0 to 99km/h (settings are for 16” wheel with 25km/h maximum).
Even odder is that when I connect up the pedal sensor, I can get it to flash once or twice, the motor starts, but then immediately stops and the pedal sensor stops working - but the controller shows 99km/h (even though nothing is turning/sensing) until I switch controller off and on again - then I can get same thing to happen again - flash once or twice as I run magnets past it, motor just about kicks in, then all goes dead again.
And the throttle won’t work at all with the “dead” PAS connected either.
(Full disclosure - the hub has been taken apart and all wiring disconnected to allow for a modified stub axle to be fitted, then all very carefully reconnected by an electronics whiz pal of mine)
At some point I will swap the two rear wheels between the Mezzo bikes to see what happens, but I am guessing that it’s maybe a settings issue?
I am NOT any kind of an expert - think I’ve just been lucky to date pairing non-Swytch motor wheels to Swytch set-ups in the past..
Thanks in advance to anyone who might be able to help!
