Swiftly problem
fishypete
Aug 12, 2024
Hi everyone I have a problem with a swiftly foldable ebike where 012 lights are displayed and no power to motor any help would be gladly received. Thanks
thelarkbox
1,620
497
oxon
one of these??
#1 check the battery voltage, after fully charging.
#2 ensure all cables are intact and fully connected,
#3 and ensure battery contacts are clean and make a good connection when the battery is slid home.
#4 check the crank axle for a magnetic disk and ensure its aligned correctly if fitted, these can easily get knocked out of place and cause issues..
your manual should list error codes , what does that say? google with the bike make and model with keywords 'manual pdf' if you no longer have a manual at hand if not already tried.
3,954
You get that when the motor connector isn't pushed in far enough. If that's not it, you have to look at the motor cable connector/s in the controller compartment at the front of the battery. After that, you have to do a MOSFET test with a meter.
