Suspension Air pressures
Lyndon
9
59
Hi I’m relatively new to e bike and recently bought a Scott egenius 720..
My question is what front and rear suspension air pressure should I be looking at?
Also new to oversized 27.5” tyres, so what pressures should I start at there also.
Many thanks in advance
Lyndon Evans
6,594
depends how fat you are but i have 160 in the front sus 260 in the rear sus and about 25psi front an back wheels.
scott gaza
162
24
scone
Hi Lyndon, You're front and rear suspension air pressure are weight related, but you want a specific amount of sag-drop when you sit on you're bike! Chances are you could have them spot on already:) Tyre pressure is more of a play off between comfort v speed with a bit off terrain handling in the mix. Personally I like to keep my tyres around 40psi which is fairly hard for mainly cycling on the roads!
