Suntours Motor problem
Jul 17, 2024
202
7
Hi all
I am trying to help out a chap who has a Carrera Vengence , suggested he joined on here but he is having an issue with that too.
(ve got the vengeance 2.1 i believe (oled display) my motor went in the original wheel error 43)
He bought a motor on e bay unfortunately it’s the wrong one so I have suggested he may be able to get his original one repaired .
Does anyone know where he can get this done if it’s worth doing ,
I have already suggested that he check all the connections from motor to controller.
He is based in Sunderland.
Cheers
Baz
3,245
Hi all
Cheers
Baz
As I said in the other thread. It's unlikely that the motor is faulty. You need to test it. The problem is probably in the cable or controller, so if the motor checks out OK, you need to test them too to find out where the problem is - probably a blown MOSFET. Error 43 is a short circuit . It should be easy to find where it is with a meter.
