Suntour XCT V3-P front suspension adjustment???
Fordulike
3,802
1,538
I've just bought a bike which has front suspension with a preload adjuster.
On the right side there is an adjuster, which can be turned clockwise and anti-clockwise, to adjust the preload tension of the forks.
The left hand side doesn't have the same grip on the top, to be able to adjust it :confused:
I was assuming what you adjust on one side, needs to be adjusted the same on the other, or don't they quite work like that???
http://www.pedelecs.co.uk/forum/attachment.php?attachmentid=3309&d=1331823404&thumb=1&stc=1
http://www.pedelecs.co.uk/forum/attachment.php?attachmentid=3310&d=1331823424&thumb=1&stc=1
Scottyf
1,403
-1
Looks like just preload adjustment and thats it.
The other bit is just a cap for maintenance.
Fordulike
3,802
1,538
So am I correct in saying that you don't need to adjust preload on both sides?
Moving on from Cyclamatic forks, I'm a complete noobie when it comes to higher tech components :eek:
amigafan2003
1,389
139
These forks only have an elastomer/spring in one of the legs - the other leg is totally empty :)
