Steering stiff
steve2wheels
Jan 12, 2020
Hi all, new to electric bikes and a little help needed please. I have a Carrera Crossfire and am enjoying it, but the steering is stiff. When I lift the front wheel off the ground the and move the handlebar it seems unduly stiff and is odd to steer and ride. Any advice please? Thanks.
Fat Rat
1,903
726
UK
Hi
Who put the bike together as I would say the headset is badly adjusted
If it's gone stiff and know one has touched it you have a bearing issue
Reactions: steve2wheels
6,516
you will have to loosen the top bolt and the 2 stem bolts. the top cap bolt could have been fully tightened why it feels to stiff.
if you do that then tighten the stem bolts means you will be crushing the bearings and why it feels so stiff.
8,533
Also check that the Crown race is fitted correctly, possible it may have been omitted which I wouldn't put past it being a Halfrauds bike. The Crown race sits at the very base of the fork steerer and is the part the bottom baring glides/rotates on.
m.knighton.mjk@googlemail
Over tight headset? Or maybe the bearings in the headset are damaged/worn
steve2wheels
Jan 12, 2020
Hi
Thanks, it was Halfords, although it was a used test bike I bought from them so. It sure if guarantee.
Reactions: Fat Rat
