Steering head adjustment
Fordulike
3,802
1,538
I apologize for hijacking this thread, but i was wondering if this was related to the same problem i have.
My handlebars are slightly off centre when the wheel is straight.
I loosened the two hex bolts as seen in the picture, but i still couldn't move the bars to align straight.
Is there another bolt under the top bit? It looks like a cap but i didn't want to prise if off in case it's not meant to be removed.
Mussels
3,207
Crowborough
That's a threadless headset and I've never had anything that modern. :)
cruiser
Loosen it, adjust it and tighten it, then tighten the locknut.
Is there something specific you want to do with it?
Thanks for replying Mussels...
My steering head was loose (fore and aft play) but my problem is, having read conflicting information on the internet, I'm not sure just how tight the head nut should be. I've already tried tightening the lower nut to a degree which seems excessive to me but, although there's no more play, the steeing does not 'stiffen' as expected, so I don't know where to stop - if you understand me.
Mussels
3,207
Crowborough
Ah, I don't know why it's not going stiff but the aim is to stop the play without it being stiff. I'd be wary of doing it too tight in case something breaks.
30,835
Any top bolt is for the head bearings adjustment, the two clamp bolts are for handlebar alignment but it may need to knocked around. Here's all the info on one of my websites:
Headstock Adjustment
Fordulike
3,802
1,538
Thanks flecc, you were correct, i was just being a pussy with giving it a bit of muscle :(
All sorted :)
