I have a Chinese generic 36v rear hub drive, silver fish battery powered bike come into my possession.
It had no battery so I've fitted a spare 48v battery that I had.
All runs well, surprisingly good bike.
There's a 2 position selector switch on the left side. "Start off" or "Pedal"
There's a throttle on the right side which on "Start Off" applies a little power to get the bike going. You then switch to "pedal" and it operates normally from the crank sensor.
Now my issue is that with it using a 48v battery off it flies, way too fast.
My question is, is it likely I can modify the controller to give full available power to the throttle such that at lower speeds, say 10/12mph the bike can run on the throttle only?
