Sprocket and speed advice
row
124
58
49
Hello all.
I'm looking for advice on how to get a bit more speed from my bike (which has a dongle). I have a rear hub Shimano Alfine , 8-Speed, It feels like I need higher gears as pedalling becomes ineffective at about 19mph, pedalling is stop and start. Is a new sprocket the answer? Also is the sprocket inside the bosch motor? Would it be costly to have fitted?
Any thoughts on this would be really appreciated
6,733
Reactions: LeighPing and row
row
124
58
49
Thank you soundwave, This vid is really helpful.
To clarify would I need only one sprocket in the front/in the motor?
Would it be necessary to get a new chain?
6,733
yes 1 at the front chain depends how much bigger you go but can just add links if thats the case ;)
Artstu
2,421
925
You can also go down to a 16 tooth on the rear, you just need to take a link out of your chain, although it also depends on how your chain is tensioned on your bike.
I've had mine as high as pedalling to 38 mph on my Nexus 8, but I'm on a classic Bosch motor.
out of stock here http://www.wiggle.co.uk/shimano-sprocket-for-nexus-8/?lang=en&curr=GBP&dest=1&utm_source=google&utm_term=DC&utm_campaign=UK_Manufacturer_DC_Shimano&utm_medium=cpc&utm_content=mkwid|sxXF5pZob_dc|pcrid|77081344872|pkw|+shimano +sprocket +nexus +8|pmt|b|prd|&product_id=
Reactions: row
row
124
58
49
This is all useful information, much appreciated - from what I gather either the rear or the front could be adjusted with a new sprocket?
I have Hub gears would this make it more difficult to do?
Also is there anyway to change the sprocket without changing the chain?
6,733
if the chain is to short you will snap it tho best get used to changing them as they wear out lot faster than a normal bike.
front sprocket will be the most simple to change and take 5 mins.
id say any more than 3t from what you have and will need to add a link or 2 to the chain thats all and simple enough if you have the tools that is.
Reactions: row
Artstu
2,421
925
How many teeth does your rear sprocket currently have?
Yes either front or rear sprocket change, or even both, I'd be tempted to go bigger on the front first, purely because of the unusual chain-line the Bosch motor brings.
The sprocket is fairly easy to change, it is held on by a circlip.
Your chain may be reused, but I'd probably take the opportunity to fit a better quality one, something like this one http://www.wiggle.co.uk/kmc-x1-rohloff-compatible-chain/?sku=5360447194
There are loads of videos showing removal of the sprocket
Reactions: row
row
124
58
49
This is all very helpful indeed.
I'm wondering how much gain there is for each tooth that is added, also if there is a climbing loss. I'm guessing that my bike has 14 at the front and this is not optimum, maybe 16 or 18 is good? (would prefer not to change the chain)
would a make like this be compatible? https://www.amazon.co.uk/Sprockets-Bosch-Bike-Motor-Teeth/dp/B00NZ51HK4/ref=pd_sim_200_2?ie=UTF8&dpID=31+bZZAfhgL&dpSrc=sims&preST=_AC_UL160_SR149,160_&psc=1&refRID=2G7SNT9PXGJ69PGS1HCD
This is the bike I have http://www.allterraincycles.co.uk/Cube-SUV-Hybrid-Pro-500-Electric-275-Urban-Bike-2016
6,733
connex are the best you can get i have 16t on mine and spin out around 29mph with 19t it got me to dongle cut off speed 35mph.
you need the socket or spanner to remove the lock ring tho.
D8ve
2,142
1,294
Bristol
I have 46 or 48 on the front with 16 on the rear with a 26' wheel.
I haven't spun out at 35mph and I can still climb 6% hill in third.
Artstu
2,421
925
From the link I see your bike has a 17T front and 23T rear sprocket. If it was my bike I'd try a 16T rear first. Obviously your whole gear range moves higher, so your lowest gear isn't as low, but the motor allows you to get away with a high first gear anyway.
You could have a play with a gear ratio calculator, but times the size of the front sprocket by 2.5 because its not set up to work out the internal Bosch gearing. so put your front sprocket as 42 teeth.
http://sheldonbrown.com/gear-calc.html
RobF
4,732
2,312
Chain length/tension is often a problem when changing the gearing on a hub gear bike.
Looks like you bike has sliding rear drop outs, which you loosen by undoing the two allen bolts on each chain stay.
No mudguards means you can move the wheel as far as the slots will allow.
Another option is to fit a chain tensioner, which then gives you lots of adjustment not least because the chain can be routed above or below the pulley.
Chain length is also much less critical because the tensioner can take up a lot of slack.
https://www.evanscycles.com/shimano-alfine-s510-chain-tensioner-EV172307?esvt=1502-GOUKE324376&esvq=&esvadt=999999-0-35300-1&esvcrea=61235636936&esvplace=&esvd=c&esvo=EV172307-NA-SVR&esvaid=50080&gclid=CO_snuWD4c0CFQaNGwodrm4J0g
Reactions: tommie
tommie
1,761
601
Co. Down, N. Ireland, U.K.
Exactly what i had to do when fitting the Alfine 8, chain tensioner needed as i have vertical dropouts, about £15 or so. Also changed the sprocket from 20t to 18t as it was maxxing out at 20mph, may go 16t, see how it deals with the hills.
row
124
58
49
Thanks for all the info guys
I ordered this
https://www.amazon.co.uk/gp/product/B00NZ51JB6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 and asked the bike shop to put it on the back.
When I returned to the shop they had put it on the front and they said it was not compatible on the back and I need a different type of sprocket, any idea if that is the case?
(previously it was a 16 at the front) With the 18 teeth on the front now it has added about 2-3 MPH - of course now it would be nice to have a bit more speed, so any idea how to optimise this, should I focus on the rear sprocket?
6,733
why did they say its not compatible on the rear? its just a bigger sprocket unless its an off set one for some bikes frame design.
go faster then cheapest option would be a bigger front sprocket you can go up to 22t size wise.
Artstu
2,421
925
This is the rear sprocket, as in the video and link above, 16 is as small as you can go, see how it goes with one, and if it isn't enough think about a bigger front sprocket
Edit, Forgetting you still have a 23 rear, the jump to 16 will be a big one.
Reactions: row
Artstu
2,421
925
Come on SW you should know the sprocket is a front one, you've got a new Bosch haven't you?
6,733
you dont want 22t on the rear lol i have 10 on the smallest on the rear but have a cassette.
