My ebike kit is on the way and I'm going to be fitting a front hub motor to a Tern Link P9, which has
already been fitted with a steel front fork.
I'll be using a threaded bar and two bolts to spread the fork by around 10mm to make the motor fit. Do I need
to worry about the two legs of the fork spreading at different rates or can I assume that each leg will spread
by the same amount?
Is there anything I need to do to guard against this happening?
by the same amount?
