My new xf07 hub wheel has a bit of spoke noise. I think it's creaking where they crossover cause noise. Something I should worry about or ignore? Wheel is fine and true
They shouldn't creek. You need to tighten them. You don't need a tension tool. I've never used one. You can feel with your hands by grabbing a couple about three or four inches apart and squeezing, like you're testing the firmness of a breast. As you run round the wheel, you'll find some looser than the rest unless they're all hopelessly loose. Make sure you understand about wheel truing first.My new xf07 hub wheel has a bit of spoke noise. I think it's creaking where they crossover cause noise. Something I should worry about or ignore? Wheel is fine and true
Only if they're all equal tension, which they probably aren't. Do the squeeze test.Give half turn for each spoke?
He's often recommended as a supplier of spokes and other wheel-related bits.I found a guy called ryanbuilds wheels easy to listen to.
I ordered spokes from him too. He's very helpful and efficient, and the spokes don't cost much. What more could you want from a supplier?He's often recommended as a supplier of spokes and other wheel-related bits.
I used him once, he was very efficient.
RyanBuildsWheels - Handbuilt Bicycle Wheels
Obsessively Perfect Handbuilt Wheels for road, mountain, gravel, cyclocross and beyond. Browse the shop or get in touch your new custom bike wheels.www.ryanbuildswheels.co.uk
No it doesn't and in any case only a tiny amount of oil is used and then surplus is wiped away after building is complete and then the wheel rim tape provides separation from the nipples.In Episode 4, Ryan applies oil to spoke nipples: Does oil dissolve inner tube?
The guides i followed said the same. - its still surprising that the nuts n bolts of this 'Dark Art' can be explained in a 10-15 min youtube..I was shown on new built wheels to place the rim/wheel on a solid surface and press down hard on the edge of the rim, working your way around it. Makes a pinging noise, and then you 'tweak' the nipples if theres any play in them.
If you dont do this and just fit the wheel you'll initially hear this 'pinging'(or clicking) noise when you first ride it, but it shouldnt I would think last that long. Just I would think the bits settling in.
That reminds me of when I was a Quality Manager. I did very many company assessments and had many discussions about how processes were controlled, mainly after things had gone wrong, and when they told me it was a black art or the guy running the process was a majician and he was the only guy in the world that could do it, I simply told them to start learning the science and start reading the manuals and/or do some experiments to figure it out until they knew how it worked.The guides i followed said the same. - its still surprising that the nuts n bolts of this 'Dark Art' can be explained in a 10-15 min youtube..
Obviously;y theres more to it than a simple vid can show, other than the basics. Dishing is one issue you'll need to get right.its still surprising that the nuts n bolts of this 'Dark Art' can be explained in a 10-15 min youtube..
