Speed sensor wire
UrbanPuma
677
43
I'm checking all wires on my controller. My ebike has nothing to connect to the red, white and black speed sensor wire on my controller. Is this necessary for the bike to work?
Pic attached
8,781
No, it is for an external wheel sensor and magnet , depends if your hub has an internal sensor. Most hubs now have an internal sensor and a sixth White motor Hall wire so makes the ext wirng mostly redundant, they are still handy to have though should the motor Hall or magnet have an issue.
If one for instance wasn't up to opening the hub & repairing the Hall , one could simply wire in an external one and disconnecting the White motor Hall wire to avoid conflict.
Reactions: UrbanPuma
3,960
These days, it's normal to have a speed sensor inside the motor. In that case, there's a white wire in the motor cable next to the hall sensor wires, and there's a matching white wire in the controller's motor connector to bring the signal into the controller.
Older motors don't have speed sensors in them so you have to use a wheel magnet type for them, which connects to that black, red and white wires connector. In that case, it's quite common that the motor cable doesn't have the white wire in it.
Some of the older versions of the controller weren't expecting the motor to have a speed sensor in it, so they don't have the white wire in the motor connector.
Whichever yo have, motor with or without speed sensor or controller with or without the white wire in the motor connector, there's always a way to connect whichever arrangement you have. If your controller has a white wire in the motor connector and one in a separate connector, both wires are joined together inside the controller, so you can use either or both.
In spite of all that, if a speed sensor isn't connected, the motor will get the speed signal from the normal motor hall sensors, but the display will always show zero speed when freewheeling because the motor won't be turning unless it's a direct drive one.
There's a setting in the controller that tells it what speed sensor you have:
0 = no speed sensor. Controller gets the speed from the halls
1 = one magnet, like wheel magnet sensor and many motors internal speed sensor
6 = 6 magnets for some Bafang motors.
Any other number for any direct drive motor. If you have a 6 magnet motor, it's not unusual for one or more to fall off so you get the wrong speed indicated. In that case you can adjust the settings, and as Neal says, it's quite common for internal sensors to pack up, then you can use a wheel magnet one and set the setting to 1.
UrbanPuma
677
43
Hi guys,
Thanks for your responses.
My motor is old, so doesn't have a speed sensor and is a geared hub. I have the magnet to go with the KT controller and display. The colours match the PAS on the bike, so would I need to put the magnet on the bike and then connect the PAS with 3 wire speed sensor? Just a thought, would this affect whether the motor spins or not?
Ps. Controller has white speed sensor wire; motor does not have speed sensor wire.
3,960
Hi guys,
The speed sensor only gives the signal for the LCD to display. It's nothing to do with the PAS. You buy a wheel speed sensor, fit the magnet to the wheel and the sensor to your frame, then connect it to the controller on the correct connector.
UrbanPuma
677
43
Ok, thanks for explaining.
