Speed error
Tomraven
Jun 23, 2023
I've fitted a 500W G020 rear hub motor to my Miami NCM bike. The only problem I am experiencing is the Das Kit C7 dispaly is showing a speed that is way too low by a factor of about 7.
The supplier tells me this could be because the new motor only has 1 speed detecting magnet and to change the value in the display.
Unfortunately my display doesn't have that level of control.
Can anyone tell me if I could possibly open the motor and insert some extra magnets or else which display I can purchase which will allow me to configure the parameter.
I may also put in a new controller if anyone has suggestions. The Das Kit Ct5-15 has nominal rating of 7A and Max of 15A which may be on the low side. At present when pedling moderately I will get up to about 38km/hr but if I pedal harder it will assist up to about 50km/hr but that was going downhill. I was thinking a high
WheezyRider
1,690
938
Das Kit stuff tends to be quite locked down. I have an older Das Kit controller and while it is possible to access settings by entering the code 8088, I don't get a setting for motor speed sensor setup. A while back (about 2 years?) someone in the technical section of the forum successfully did a mod on the firmware of an NCM Moscow (with Das Kit LCD) I think it was. Might be worth having a look there.
Reactions: Tomraven
WheezyRider
1,690
938
Found the thread:
Might be worth talking to @jokskot
