Thanks for the info, I’ll let him know.Located in Warrington,the bike is 19``,top speed with the gearing fitted is 67kph on the flat,but i have had it to 73kph with a slight tailwind at power level 8,the BBSHD is a good performer with a powerful battery.It is now fitted with a chainring adapter so bigger chainrings can be fitted if needed.There are 9 power levels so you can go slower.
It just misses when tightened up but it is very close.Hi,
I got a Rockhopper same one as yours just fitted the motor i find that the reduction gear just rests against the chainstay but it goes fully home did you use a thin spacer or just let it touch the chainstay?
Regards
Mark
Now on ebay with a new 17,7ah 30Q battery and upgraded wheels.Hello mate, I'm interested in the bike.. How would you like to proceed?
