Sorry for a newbie question. Turn off thumb throttle.
Largewell
Oct 27, 2020
Could someone please help me. I have a Bafang 350w hub drive with a KT-LCD1 controller. It has a thumb throttle controller that I want to disable. Can someone please help me.
8,842
To disable it unplug the cable at the controller.
One can select P4/1 in the basic settings that only allows it's activation only after pedalling, but it doesn't disable it.
Largewell
Oct 27, 2020
I just purchased another 10 bikes for my ebike hire business. In our country it is illegal to have a thumb throttle and all the bikes have been supplied with an active thumb throttle.
I need to either remove or disable it to comply with the law.
8,842
You will have to remove them to disable with LCD1.
If you buy an lcd3 then you can use it to change all of the controllers parameter and set it to C4/1 = 6km/h walk assist. Simply unplug the LCD1 connect LCD3 make the changes switch off and reconnect LCD1.
3,994
Throttles are not illegal in any country as far as I know. You can have one that opearates up to 6km per hour or have one that only works when you pedal. There are often settings in the LCD that allow you to set its mode of operation.
If you want to get rid of the throttle for whatever other reason, it's a simple matter of unplugging it, undo the clamp screw and slide it off the handlebar.
Reactions: MontyPAS
