So wobbly wheels are ok then??
sneggysteve
80
39
Let's start by saying I am a novice here.
Short version – Mid Jan had my 10 year old Giant Sedonna converted by local company. Rear wheel cadence sensor hub.
By March there was a clicking sound coming from the rear wheel. Took it back and was told it was the spokes (see more below)
Mid May and the clicking is getting worse and finally got hold of him to look at it again this weekend. The clicking is a regular noise rather than a random. The clicking occurs whether pedalling or not and with and without use of the motor so the wheel is the problem? At this point I also found a wobble in the rear wheel which I would guess to be a 2mm movement. Bike has done just over 700 miles.
He took the bike for a quick ride but did not remove the wheel or anything else.
His written response as follows (his spelling) -
"1. Small amount of play in hub motor baering - All CSC hub motors have a very small amount of play in the bearing from new, this can increase by a very small fraction when worn in. On inspection of your bike I can confirm that the very minor movement is within tolerance.
2. Noise from spokes - When this issue was initially reported we had you bring in your bike under warranty. As discussed, we found that some of your spokes had become loose, I re-tentioned the spokes and made sure everything is in working order. There was still a very minor noise coming from the spokes due to where they had rubbed away the black coating in some places. As with all rubbing spokes this can be resolved with the application of grease. This kind of ware and tare is quite normal. "
Is this correct or am I being shafted here?
Steve
2,756
That sounds correct. Especially if you are fairly heavy you can expect spokes to loosen. It won't happen on a really well built wheel. Maybe the wheel they put in for the conversion was not very well built and tensioned, but I don't think you are being shafted.
GSV3MiaC
211
134
So does the click speed match your road speed, ie once per rev? Could it be brakes (what type?). Does it click if you invert or dangle the bike and rotate the wheel?
sneggysteve
80
39
Yes regular click once per rev. Checked brakes old style blocks and its not that. Click only happens when riding - not when wheel lifted off ground
3,993
He
I just had a similar experience. I am not as heavy as you (85kg) and started hearing this clunk.
Turned out to be the axle was eccentric. Mine was a mid-drive motor, it sounds like your rear hub motor has a similar issue.
The thread is here:https://www.pedelecs.co.uk/forum/threads/2-years-on-with-the-tsdz2.41325/post-618583
He has a cassette motor with a 12mm axle supported on three bearings. The chance of it getting bent is close to zero. Yours was probably 9mm, which is fairly easy to bend - even worse if its a freewheel. That's another disadvantage of using crank motors, especially high power ones. The forces through the drive chain are massive, and much more than what it's designed for.
vidtek
423
243
Bournemouth BH12
He
I really don't see a motor, certainly not a 250w motor exerting more force on a chain drive system than a big man standing on the pedals to drive a bike up a hill. Sorry, that's just not possible in any scenario.
I think you were right about the 9mm axle, that's about the size of the spindle.
Cheers Tony.
sneggysteve
80
39
Update on my original post.
Took bike to proper bike shop - Plan2Ride in Tongwynlais just outside Cardiff.
Spokes - there were a few that were not seated correctly in the hub.
Wobble - cones needed adjustment
Now a silent bike!!
Thanks to Plan2Ride for excellent service - highly recomend them
StuartsProjects
1,786
1,009
Thats just opposite that really nice hill up past Castel Coch.
Do you know if they would do a good job of building a complete rear wheel if provided with a 250w hub motor ?
