Does anyone know what the smallest in frame battery is? As in physical size.its for a full suspension frame with the rear shock upright next to the seat post.
Pictures helpful to understand what you want to do.Does anyone know what the smallest in frame battery is? As in physical size.its for a full suspension frame with the rear shock upright next to the seat post.
To be worth the effort, it needs to work well as an eBike, which means a battery of enough volts and also capable of enough amps, and the size follows from that.Your first impression is correct,and I've seen it done,was just thinking smallest possible to make it easier.ah well....back to the drawing board.
