Small frame ebike
Crystal_pixie
41
53
Bristol
It's looking like I might have to hand my Kalkhoff bike back due to motor problems.
I have been looking at alternatives and I am struggling to find a smaller frame as I am only 5ft 4in with a 29in leg.
The kalkhoff pro Connect is a huge frame and a little cumbersome. I would like a step through again. I like the look at the Wisper but the frame looks quite big.
Up to £2500 to spend.
JuicyBike
1,671
527
Derbyshire
CP
You should be okay on an 18" frame.
Which model of Wisper do you think looks too big?
Gaz
720
556
54
Eastbourne
My wife is 5'5" and her Wisper 705SE suits her just fine. We've just measured and she has a 29" inside leg. Hope that helps.
Gaz
Wisper Bikes
6,282
2,252
69
Sevenoaks Kent
Yes, that's the one.
This our torque model, 575Wh battery, torque sensor, hydraulic brakes, silent run. Have a test ride, I am sure it would suit you.
Here she is...
All the best, David
Reactions: Gaz
Crystal_pixie
41
53
Bristol
All the best, David
Thanks David it does look interesting. Is this a hub motor or a crank? I have been used to a crank motor but I am not too sure of the differences!
6,490
Wisper Bikes
6,282
2,252
69
Sevenoaks Kent
Hi CP, It's a hub, but feels very similar to a mid motor. We have a torque sensor and the power deliver is very smooth and quiet. It would certainly be worth giving on a quick whirl!
All the best, David
JuicyBike
1,671
527
Derbyshire
CP If you prefer both feet fully on the ground, which is probably not so good for your knees but might help less confident riders, then a 17" frame like our our Poco might be a good choice for you.
Crystal_pixie
41
53
Bristol
my present bike I can only just touch the ground with the tips of my toes with the frame bent across slightly. That is with the saddle at the lowest point so its not because of confidence its because I am a shortie!
Trevormonty
1,135
564
17
NZ
Add a dropper seatpost and you can always have your feet on ground when stopped. You will have to forgo a suspension seatpost.
Fat tires and coil sprung seat should help.
JuicyBike
1,671
527
Derbyshire
Understood CP. Sarah at Juicy is also not quite able to ride an 18" frame, like our Classic or Roller, but is very happy on a Poco or Compact.
Trevormonty
1,135
564
17
NZ
I need to check out drop seat posts now - still learning.....
Dropper posts were designed for MTBs, dropping seat so you can get you butt and weight over rear wheel on steep descent. As I've discovered along with lots of others is they also allow you to lower seat when stopped, a nice bonus.
Typically they have remote leveler on handlebar, push it while seated and it drops. Push it while unweighted up and seat comes up. They take about 10min to get use to then there is no riding without one. Test riding high end MTB is probably your only way to experience one.
See Google and Youtube for more info.
