November 3, 201510 yr Hi, I was hoping someone might know what my problem is, or even if I have a problem. Have just bought a Z6 Zipper I already have a cyclomatic power plus and I had a 20 inch wheel one before that for a very short time. Bought this new at a good price. The thing is it is pedal assist and throttle, I have only been to the top of the road and back twice, stopping along the way. The pedal assist takes quite a while to kick in, about 8 or 9 full revolutions of the pedals. The other two bikes the motor kicked in as soon as I pedalled. Has anyone else come across this, I really think something is not right. Thanks.
November 3, 201510 yr I don't know this particular bike, but.... Have you tried a lower gear so that the start up cadence is higher? The other trick is to blip the throttle as you start to pedal, power should continue when you let go of the throttle.
November 3, 201510 yr Author Hi, Thanks for replying. I started of in low gear both times, I also did the throttle but it didn't help. I am quite puzzled because the throttle works great.
November 4, 201510 yr Are all the magnets still on the PAS disc or even more likely is the magnet ring close enough to the sensor?
November 4, 201510 yr Author Are all the magnets still on the PAS disc or even more likely is the magnet ring close enough to the sensor? Hi, Thanks for that. Excuse my ignorance, I may have had two bikes before this and have learned some stuff along the way but have never messed about with sensor magnets before. To check what you are saying does that involve removing the crank shaft?
November 4, 201510 yr You should be able to at least check it with the pedals still fitted. It should look remotely similar to the black disc in the below picture, the black box with the wire is the sensor for the PAS and it detects the magnets on the disc rotating past, if the gap is to big it will need to spin faster to tell it it is working as some of the magnets may not register if the gap is to big it won't work at all, if the disc is loose it may not spin with the pedals correctly either or a magnet missing etc. Good luck Edited November 4, 201510 yr by Geebee
November 4, 201510 yr Author You should be able to at least check it with the pedals still fitted. It should look remotely similar to the black disc in the below picture, the black box with the wire is the sensor for the PAS and it detects the magnets on the disc rotating past, if the gap is to big it will need to spin faster to tell it it is working as some of the magnets may not register if the gap is to big it won't work at all, if the disc is loose it may not spin with the pedals correctly either or a magnet missing etc. Good luck That's made it clear, thanks. I have looked at mine, it is on the side where the gears are. Just rotated the pedals by hand, it looks very much like the magnet disc itself is out of shape with the sensor then being close then further away as it spins. Could that cause my symptoms or would that make the assist cut in and out... just thinking aloud. If the disk is bent, home it's not the cog, can it be straightened?
November 4, 201510 yr Yep you found it! That used to happen to mine if I touched it with my foot while pedalling. You should be able to adjust it by hand so that it runs parallel.
November 4, 201510 yr Author Yep you found it! That used to happen to mine if I touched it with my foot while pedalling. You should be able to adjust it by hand so that it runs parallel. As I said earlier I have not messed with disc magnets or sensors before, or cranks. To get at the disc do I need to take the whole crank out or just the disc side, I bought a puller tool last year but have never used one before, I am just a bit wary of the process, even though I do like to have a go if I can.
November 4, 201510 yr The disc is just a friction fit to the crank shaft, you can adjust it with your fingers to run parallel and about 1 - 2 mm from the sensor.
November 4, 201510 yr Without taking anything off you should be able to adjust it. It is just slipped on over the BB axle. Maybe you will need to use a screwdriver because there us no space for your fingers? Can we have a photo? edit : posted at the same time as oldbob
November 5, 201510 yr Author I got it straight then took it out, about a mile there and back. No change I still have to pedal a lot before the motor kicks in, when it does it feels just the same as when using throttle, not a gradual help but a burst. I have enclosed two pictures trying to show the sensor and disk. The sensor is on a bracket but the bracket is tilted upwards which makes the sensor tilt upwards. I know nothing about these things but it appears to me that where the sensor has been fitted it would not directly face the disc, it would be too low so it has been levered up somehow. The gap also appears too wide maybe?
November 5, 201510 yr I would suspect the PAS sensor is working OK, could be a problem with the controller? causing a delay, maybe worth contacting the supplier?
November 5, 201510 yr Author I would suspect the PAS sensor is working OK, could be a problem with the controller? causing a delay, maybe worth contacting the supplier? I intend to, well the bike seller anyway, I just wanted to be armed with a bit of an idea what the problem could be in case they try to blind me with science! Does my sensor look right, in my pictures, it looks to be angled upwards to me, as if the bracket it is attached to has been bent upwards?
November 5, 201510 yr Nope doesn't look right. As you reasoned it should be parallel. Something has hit and the sensor has been knocked up and your disk was also displaced before you straightened it. Maybe the sensor doesn't have enough magnet surface coming by to detect it like it should?
November 5, 201510 yr Author Exactly what I thought. Anyway I have written to the seller but I won't hold my breath for a reply or any help from them even if they do reply.
November 6, 201510 yr Have you tried bending the sensor bracket back into line so the sensor sits flat to the disc, basically you want the magnets in line with the sensor as they go past.
November 6, 201510 yr Author Have you tried bending the sensor bracket back into line so the sensor sits flat to the disc, basically you want the magnets in line with the sensor as they go past. Can't do that, it looks like that's why it's bent in the first place. If it was straightened out as it should be the sensor would be below the disc. Seems the sensor should have been put in a different place, that's just me thinking.
November 6, 201510 yr Looking more closely it looks like the disk diameter isn't adapted to the sensor position? Very strange.
November 6, 201510 yr Author Looking more closely it looks like the disk diameter isn't adapted to the sensor position? Very strange. Could that be mismatched parts? I thought it was a bit odd myself, especially with the sensor beng bent/angled upwards.
November 6, 201510 yr Author Looking more closely it looks like the disk diameter isn't adapted to the sensor position? Very strange. Do you think it could be a mismatched set, highly unlikely I know but..... It does look very odd, I have been looking at a few correctly fitted ones and they look perfect in every angle. Getting the supplier to believe this is going to be very tricky, if they ever reply that is.
November 6, 201510 yr Author Do you think it could be a mismatched set, highly unlikely I know but..... It does look very odd, I have been looking at a few correctly fitted ones and they look perfect in every angle. Getting the supplier to believe this is going to be very tricky, if they ever reply that is. Sorry, repeating myself there! Thought the first one had not gone.
November 7, 201510 yr Author So, the thing is, even though the bike is brand new it has no guarantee, to speak of because I got it at a very good price. It looks like it's down to me to sort it out. If I was to buy a split ring disc and sensor and just disconnect at controller and plug the new one in could that work? I'd rather get this one working if I could, is there any chance the controller could be causing the problem. Thanks.
November 7, 201510 yr If you turn the bike upside down, after checking nothing on the handle bars will get broken Turn the bike on and test as is by turning the pedals until the motor comes on (this is just a reference point) then try getting the sensor more inline with the magnets and test if the fault goes away, you could remove the sensor and just tape it in place for a test, you could hold it by hand being careful that the chain and sprocket doesn't remove a finger, or bend a Z bend into the bracket to align the sensor if there is enough space, at the very least you should be able to verify the sensor position is the culprit before buying new bits. On the plus side look how much new knowledge on e-bikes and how they work that you are getting
