What is that trick to charge a single cell with a mobile phone charger, i.e is it as simple as taping the charger+ wire to + and charger- wire to - on that cell only even still connected in the pack? what volts or milliamps should the charger use? and what volt should I take them up to?
I have a cree led 4 cell battery pack which is not charging, they look like the ones with the protecting circuit in the ends I think. All 4 cells read 4.05v and the pack reads 8.1 so am hoping the mobile phone charger trick will spring it into life.
