Sine wave vs square wave vs dual mode
David Groen
I have successfully converted my Sparta RX to run on generic components using the original front wheel motor. I have a Brainwave controller which does everything I need, but is rough under about 5mph. Many posts recommend KT sine wave controllers and LCD display which are slightly more expensive, but that's not a problem. The one I'm looking at is dual mode, but I can't find any info on whether this is square or sine, or if it will cure my low speed lumpiness. I'm using Hall sensors, I'm a gentle 250w commuter in flat Worthing so I don't need raw power or high speed.
Any thoughts before I shell out?
thelarkbox
1,190
360
oxon
Hi, That ad is a bit 'fishy', Very good price for a 20a controller +lcd3, however Dual VOLTAGE controllers are very common, dual mode controllers ie sq-wave Or sine wave?? which is what i think that ad alludes to? I too would be asking questions.. - You could take a punt and if its a 'scam' rely on ebay returns /paypal refund..
do KT do a 20a controller?? i seem to recall 17a and 22a being the options to upgrade from 13-15a??
Myself i would probably pay the extra £10-20 or more for a 20a, and buy from a supplier like topbikekit, who detail everything in the ad descriptions leaving no ambiguity..
edit -- also 9x msffets is preferable due to better load distribution and heat dissipation.. 6x versions run hotter..
Reactions: David Groen
3,124
It used to be ZWS in the designation number is sinewave and SVP is squarewave.
I'm not sure that KT are the best for some motors. I had rough running with a Q75 motor that I solved by adjusting the P1 parameter by trying various random numbers.
Some controllers, like the old KU63 and KU65 from BMSBatterywork well with any motors, but they don't have LCDs.
