I've studied a number of threads on here that have approached this topic from either motive, that's to say:
1. de-restricting a road legal 250w bike so that the motor will continue to provide power even when the wheels are going faster than 15 or so mph (ie when being pedaled faster),
and 2. adding a switched restricter to a powerful motor setup so that it's pseudo road legal by preventing it from doing more than 15 mph while switched in. (I realise it would still have a non road-legal greater than 250 watt motor, but it's part way there ).
Reading some posts on here, it would seem that method one involved disconnecting a white wire on some controllers ?
Whereas method two has had some suggestions for additional circuits with trimmer pots and switches to restrict the motor power ?
Method one seems more elegant and foolproof, (if I understand it correctly, directly knobbling the measured speed, rather than just throttling the maximum output power, which could be inconsistent on steep hills ?)
I have the X8M06-c chip in my controller, running a 1000w 48v motor at 36v (which is running nicely, thanks to the help I had from here). Is there a "restricter" pin on there that I could enable, or is that a feature not available on that chip ?
