I've a Shimano Nexus 8 geared hub laced into a 26" wheel with the coaster brake kit fitted. This hub has a fault that the middle 3 gears do not engage properly. I've replaced the bearings and the gear change mechanism but it needs someone with a bit more knowledge than me to look at the core. Hence £40 for the wheel.
Next up is a brand new 33T chainset for the Shimano Nexus, it's a single chainwheel, brand new for square tapered bottom brackets. £20 as new.
Lastly a Nexus 8 speed twist shifter as new £15.
Let me know if you're interested in any of the parts, if you want the lot £65.
