I’ve just converted a brand new Giant LIV hardtail bike with these brakes fitted. I’m 14-15 stone in weight. They appear to be correctly adjusted etc. However, coming downhill over extended distances >0.5miles and quite steep (required maximum assistance and lowest gear to climb) the brakes are being fried.
I need to correct this, any suggestions?
The brakes require resin pads to be fitted which I assume they are.
I have a similar problem with a set of Tekno Auriga brakes on my Boardman road bike but there is no such restriction on the type of pads used so I’m progressing from resin to sintered and soon to ceramic or “professional” - basically more expensive to see if one type will work.
