Setting the record straight!
Gaynor
152
I see the thread is locked after a load of rubbish was posted, which is not fair that I dont have my say, I received the bike as Flec said, in what I thought was perfect order, so I posted, but on the second ride after the bike brake failed. So please Flec dont twist things.
When I received the bike the 2nd time it was damaged, I phoned the company, so dont know where your talking from.
Also at the end a lot of positive was coming out of that thread, new questions asked.
I forgot about the PM section bit, I will take on board the excellant advice given there. Which is supportive, not a slant against my character.
I have only written here the facts about my bike, but burned to the ground, as 'some' people will only use selective reading. I notice you didnt post the problems, and infact I got an email telling me I was making the comapny look bad because of my bike problems, this was a year ago, I delted those post, last year, I wish posts could be retrieved.
Good night, or rather good day.
Gaynor
Quote:
Yes, the part is the same Gaynor, but for some reason it doesn't seem to
be fitting quite right. I wonder how it would fit if you tried fitting
the front two screws first, then attach the one at the rear last. You
might need a slight shift of the clip that attaches it to the frame tube
when you do that rear one up last. It's difficult to tell from photos,
but I think that might work if it's done in that order. These casings
can be very cussed. On my Twist bike, the plastic motor casings are so
difficult to refit that one could swear that they are the wrong size,
but once I succeed, they seem to magically be ok!
Won't the chainguard brackets straighten? It should be possible with
pliers or an adjustable spanner to twist that lower bracket straight.
I think the pedelec sensor is the problem, since that's a part of the
bottom chainguard strut. I'm attaching a photo of it how it should
look. This reads the rotation of magnets in a black disc on the back of
the chainwheel, behind the strut. It should have a tiny clearance if
you look between the strut and the chainwheel to see where the two are
close. 15/12/2006 18:22:55 GMT Standard Time
Flec goes on to say - It was carrier damage, not your doing.
What's happened here is that the carrier has knocked the base of the bike and dislodged the fastenings of the lower half, and it's probably the carrier who's done the scratching too, judging by that rough handling and the delay in your getting it.
In this case, I've had a look at the photo and it's apparent the
chaincase.
I've been following your
troubles and know of the frustration that you've suffered.
Unfortunately, because it's small and new, the whole of the electric
bike industry suffers from the way the products and service are
handled. However, costs are a problem, taking bikes back in from a
distance can be a very expensive thing to do.
Gaynor says -when I phoned 50cycles, which was straight after I realised what was wrong, and that I still couldn't use it, and then being told to use it without peddling really got me cross. can see their side but I felt they should see my side too, seeing as I only had it 2 weeks, and then get it back in that condition (un rideable) but maybe this can be sorted out easier, I hope. The well known companys on the net would replace your bike in good condition, or give you your money back, my gripe is with the condition I recieced the bike, photos can be seen on other closed thread.
So I did not 'imagine' the problems as was said on the second from last post on the 'problems thread, as quoted selective posts in the now locked thread, as I sent photos of the damage when I opened the box, of course I was delighted when I first recieved my e bike, the first use even made it up to the top of Croft road, fairly steep, but it only made it once, after that the power cut off, I merely needed to get this point across, because it came across as in a whole diffreant light, selective quoting.
Posters saw the condition the bike came back in, I didnt know it was unridable until I took it outside and discoverd the chainwheel mental part was quite bent, it caused the mudguard to stop the bike from being used, I am a lady, I pay for people to do thw work I dont/cant do, like a lot of people, I am a busy mum too, with two special needs children, my e bike is my only form of transport, the buses round here are like once an hour, at one time I would of used the bike to take me up to the Conquest hospital for more blood, but now theres no way I am going to attempt to take the bike all those miles, when I have used it of late, its when I have been riding on the flat, and stopping, goiung extremly slow on the hill, but get of and walk, this is after the 2nd brake failed, which was only 2wks ago, it didnt brake on a hill, just turning a corner.
the_killjoy
822
226
Why do you carry on having a go at Flec, the quotes you have posted seem to show that he has been trying to help you with insructions and photos.
Try to use your energy to solve the problem not carrying it around with you.
bode
626
Hertfordshire and Bath
Go away
I am losing the will to live, here!
One thread gets closed down because of the endless screeds of rubbish from somebody who just does not understand when to leave it and move on, only for another to pop up.
It's like dry rot.
PLEASE, do us all a favour and spend the same amount of energy that you waste on invective in getting your bike sorted out.
oldosc
207
10
It's like dry rot.
Hey Bode
Don't ask her to quit man, it's Ok for you... probably a youngster of less than 65, with a working bike, out funninabout. Me.. Aggatu in bits, spent all morning looking on web for manual of how to put a nexus back in the frame... totally failed.My manual says "Fuhrungssten der Fixierbuchse nach oben drehen" (among other things)..Flecc is not online..Lady J is out on her pathetic Silverado.
It's a real gas to read while waiting for some-one to pick up the post:rolleyes: :rolleyes:
:cool:
bode
626
Hey Bode
:cool:
Only by 2 years.
Oh well, far be it from me to be a killjoy. If everyone likes that stuff and being insulted (so glad to have joined the club), then fine!
You could probably power a small town with the wasted energy, though...
Jeremy
1,010
Salisbury
Look, the vast majority of people on this forum (read it, and then show me otherwise) are fair and reasonable. This:
people know how this board works, its bias at times, and so one sided.
Is complete and total rubbish.
You had numerous offers of help and advice, ignored most of it, it seems, yet continue to complain about the membership here in general terms.
If you think the forum is biased and one-sided, then go find a forum that isn't. None of us on here are paid by anyone to give help and advice, any advice you have had from here has been freely given by volunteers, not salesmen/women.
Can we please stop this thread, and please don't start another in the same vein, many of us are getting more than a little sick of this subject.
Jeremy
Gaynor
152
Old sock says
I didnt even get a manual with my bike, I got some info about the battery that was all.
My mother isnt even 65 :rolleyes:
Boys will be boys.
Jermemy if info is given incorrectly, and I have the proof and photo dates to proof it, then of course its bias, I am not going to be quoted on things said and suddenly the thread gets locked.
If you dont want to read me then please just block me, I feel that some are enjoying it. As I said, too many dogs on one bone, thats what happens when people are friends on a forum, and anything said, Imo, is then slated, if the thread were to be locked it should of been locked after being called names.
The advice given will be taken up by my Bf tommorrow, as I have some excellant advice via Pm/and mail.
Have a nice day now, dont get yourself an hernia.
rsscott
Administrator
Staff member
Aug 17, 2006
1,399
196
Folks, please keep things civil, follow the rules.
Gaynor, please do not allow your account to be used by someone else. If Freek wishes to post, he must register for his own account.
May I also remind people that swearing is not acceptable. I don't even want to see abbreviations used or other ways to display expletives.
oldosc
207
10
__________________
Is it alright to use 'expletitive deleted"
oldosc
207
10
ook at names like ehh ow yeah 'oldosc' now what could be behind that stating words well do i need to elaborate about the polite.
Gaynor..lighten up..from the posts you have had a bad trip..Sometimes in a while we all like to hear a bit of passion it is good everyone dont lie down and be too polite..mimsy..BUT you have had a good run here..swallow the bad(ish)times move on.. be a bit of a forum member..contribute..or (expletive deleted) off
