Had a cracking day out yesterday from the house and only crossed one bit of tarmac... The tubeless and lower pressures are amazingly better, as are the 160mm cranks- only one pedal strike and that was my bad timing...I made it to the peak of the last hill and the battery literally died which meant a descent to the house.... The distance and elevation aren't bad and not once into sport/turbo, but the plans I have for the summer once the snow is gone from the peaks mean that one battery won't be enough to get on the Cairngorm plateau and go very far...or do some lower level "E-bikepacking"... So I've taken the plunge and ordered a second battery...suppose it means that any day I want from the house I can go out on one battery while the other is charging, pop back for lunch and a swap and do the same again so potentially keep out as long as I want!!!
