My wife's Santana 3 suddently and without any warning cut out the other day on the way to work. The display went dead, not even a backlight, and the motor stopped supplying power. She had to cycle home unassisted. It has been very successful and came with one factory mod - we requested Woosh to fit it with a torque sensor crank and KD58C LDC control as we both greatly preferred torque sensor ebikes to cadence sensors when deciding what to buy a few years ago. The LCD won't come on when the on button is pressed and there's no power from the motor.
When she made it home she charged up her bike overnight and the charger light turned green so presumably the battery must still be charging. I did check that the physical switch on the battery was on.
As I have the same torque sensor and LCD on my bike (retrofitted as a kit), I swapped my LCD over to her bike, but it also failed to turn on. I then tried my wife's LCD on my bike and it seems to work fine powering my bike.
I've eyeballed all the cables and it doesn't look like anything visible such as the connection into the hub motor is damaged.
So in summary we have a Santana 3 that won't turn on, yet the battery seems to charge, the KD58C LCD controller works on another bike and none of the cables appear damaged or unplugged.
Please could someone suggest what the next step should be and how I can get this fixed, bearing in mind I have minimal tools, limited electrical expertise and my local bike shop won't touch e-bikes?
Supplementary question - if it needs any new parts can she continue to ride it to get to work but unassisted without causing any damage (minus battery due to its weight penalty)?
