s866 Power Assist Sensor Direction Settings
GIovaArcade
Mar 20, 2023
hi guys a couple of days ago i bought the s866 display to replace the KD21C that got damaged. does anyone know how to configure Power Assist Sensor Direction Settings ?
when i pedal forward the sensor doesn't work but if i pedal backwards it works.
Power Assist Sensor Settings PAS represents power assist sensor settings. Power Assist Sensor Direction Settings “run-F” means forward direction while “run-b” means backward direction. The default valueis“run-F”. Press the UP/DOWN button to select F or b to change the direction of Power Assist Sensor. Press the ON/OFF button and then access PAS sensitivity settings.
8,517
If he default setting is " run - F" and it still works backwards, try " run - b " to see if it works correctly.
Otherwise rotate/reverse the disc magnet face as the poles are sending the wrong signal.
