Still trying to sort out my A2B Kuo + folding ebike.
All is good, throttle works fine, even when the 5-pin LCD is disconnected.
Troubles with the PAS, and so I have now acquired KT controller/display to replace some generic lcd/controller combination which may not be performing too well together.
The original controller appears to have had a sm connector (white green yellow) from the battery (separate from the main +/- power connectors).
I am not sure if this is still needed on a more modern controller/LCD combo, since there are other signal wires which might well be able to transmit/receive info between the battery and controller, such as battery state of charge.
I include piccies of the battery type and the connector for battery output, which shows the RX/TX output/input conns.
So, to repeat what Ive said, does the RX/TX conns at the battery need to be connected somehow to the KT controller, or can this be ignored ??
