Rogue Ebike motor
zabka
May 31, 2020
Hi all,
I have an older Carrera Vengeance E spec and recently the motor starts going as soon as I switch it on and won't stop until I switch it off.
Has anyone an idea what could cause this?
Many thanks
8,839
Likely a wire short or electrical contact shorting in the display activating the motor via the controller.
8,839
Only if one can trace where the issue is.
Water ingress is one possibility or a broken /intimittemt wire.
I had a Julet connector once that water was ingressing , it caused a green copper track between a pair of pins thus causing the short .
Most likely may be the display internally either water tracking or a loose/broken wire shorting another.
