Rockrider est 520 thru axle adaptor for trailer
Douglas
Sep 20, 2021
Hiya. Any help appreciated. I'm trying to find the correct thread pitch for the thru axle on a rockrider est 520.
The thru axle is 148 x 12 and I'm looking to buy an adaptor axle that can attach a kiddy trailer to.
There are axles out there but I need to know if the thread pitch is 1 , 1.5, 1.75 etc.
Cheers
6,722
well in that size there are onlt a few axles that would fit that frame.
44108
so the total length should tell you what you have thread pitch wise but think it is maxle boost but double check this.
Douglas
Sep 20, 2021
So measuring the thread length is the answer. If its 20mm then its a maxle boost with pitch of 1.75 mm. Ace, thanks.
6,722
yes the total length and thread length will tell you what the pitch is my haibike uses maxle standard t8 non boost.
using the wrong one can end in disaster like t1 in a fox fork will mean the tread is 1.5mm to short but it will fit.
Reactions: Douglas
Douglas
Sep 20, 2021
Many thanks
Harry r1
Mar 7, 2023
Hi sorry to jump on an old post but did you successfully manage to purchase the correct thru axle adapter ?
