I have been using a 12S (44.4v nominative) battery for a while now around town, today was the first real world test and the 15 A 36v KT controller failed this test...
Usual road to Hendaye, 12.7 km to the factory where SWMBO works:
On the way (above image) all went well until the main hill where about 35-45 seconds in the controller cut out. I was pulling about 700 W peak, over 600 W constant. Turned controller off, turned it back on and away it went again for a few seconds. I think this was a thermal issue but can't say because the controller is in a plastic box that is screwed tight.
On the way home I turned the power down (32 tooth chainwheel instead of 42 tooth) and all went fine with a peak at 649 W but mostly around 500 W climbing back up the hill. I used 7.1 Wh/km on the way home
I will swap the controller for a 36/48v 20 A one to solve this issue.
It was a real road test, on the way I rode through a thunderstorm! Had to stop for the hail, couldn't see and couldn't feel my fingers... The wind gusts were the scary bit!
