The advice on this forum is to try as many e-bikes as you can to ensure it is right for you.
So having ordered a Riese & Muller Delite 2, not only not riding one but never even seen one other than a photograph on their web page, I was a little apprehensive when arriving at Onbike's showroom.
I had no need to worry; the bike looked so good it was a delight to see it. The build quality is exceptional and the component parts being of the best available to suit the design of the bike. R & M's reputation is well deserved. It felt instantly right as soon as I got on, the bike could not have been better if it had been tailor made just for me.
Certainly it felt different to any other bike I have ridden. I can only explain it is more like a Harley Davidson than a Triumph or Norton and I've never ridden a motor bike, but that is how it seems.
I did check the Geometry dimensions and compared them with my existing bike and with the Grace MX that preceded it, so it was not a complete gamble.
I chose to have the Rohloff geared hub, not wanting derailleur or NuVinci and I am so glad. The gear range is great, better than my 3 x 8 derailleur on my non powered bike, but of course it is costly and a decision not taken lightly, but for me worth it.
It is Bosch mid motored so nothing different to most others but it is the Performance version and therefore has more torque. A test I did was a steep hill, about 20%, last ridden with the Grace MX. I thought at the time a little lower ratio would have been welcome as it was hard going. With the Delite I put it into fourth gear and high power and just breezed up. Whether it was a lower gear or the higher torque I don't know, maybe a touch of both but it made riding a real pleasure.
I have been wondering if it free wheeled as well as my other bikes, but the high winds have made it difficult to ascertain this. However, following a non powered rider in a sheltered lane I noticed he kept peddling, I had to brake. That was pleasing.
Changing gear with the twist grip takes a little getting used to, additional problem for me is that it works in the opposite direction to the NuVinci and in my old befuddled mind I can get it wrong when changing hurriedly when in panic mode. I hope to adapt. Gears change without any drama, having to ease off the pressure when changing down, changing up not always necessary. Always a smooth change and the control is clearly numbered.
I chose to have 26" wheels although 29" are also available. I have ridden 29er's and found I preferred the smaller size, seemingly a little more manovable on the tracks.
There is an active pivot swing arm to ensure optimal road contact along with air-shock front dampers. Hydraulic disc brakes stop the bike readily and the Schwalbe Marathon Deluxe tyres ensure a good ride on hard and rough surfaces.
Almost reaching 200 miles I thought I had better write something, especially having had someone give a nudge (thanks RobF).
So far, I can only conclude that, if funds permit and you want quality, you can't go wrong with this bike. Money can be saved by choosing to have derailleur gears instead of Rohloff, and of course NuVinci are also available.
