Woosh Revisiting my first conversion
Peter.Bridge
1,586
728
So my very first conversion was 2 years ago. I fitted a Woosh XF08c kit to a Claud Butler step through bike (with rim brakes !)
It has a 36v 20Ah rack battery with I believe a Lishui 18 amp controller built into the battery housing
I was very pleased with it and my niece "borrowed" it to use at University.
She has been out riding with my sister in the North York Moors and on some of the longer hills at full power the motor has been cutting out (I'm assuming the controller is overheating). This used to happen to me before my niece borrowed it
If they take a break it starts working again fine
The other thing that has become a bit hazardous is the rim brakes, particularly down some of those hills !
So my plan is to swap donor bike to one with disc brakes
Would it matter if the new donor bike has "27.5in" wheels (motor wheel is 700c)
What should I do with controller ?.(My niece is 60-65 kg)
Replace with like for like ?
Mount controller outside battery housing (cooler ?)
Get 9 MOSFET or 12 MOSFET controller + matching display ?
8,736
I found when my S06S started cutting out due to thermal cutout that it happened more often and quicker once under pressure.
Mounting outside will likely not make much difference, after mine cut out I fitted another heatsink , two small 5v fans and supply but tbh it made little difference.
A larger mosfet model likely won't fit inside the battery compartment (though one can check) so it will have to be exterior sited.
Reactions: Peter.Bridge
3,763
You need to establish what causing the cutouts before changing anything. If the LCD goes off, it's the battery, and if it stays on, it's the controller. Which is it?
You can use the 700C wheel as long as it fits in the space with your tyre of choice. You need to take measurements to be sure there's clearance behind the chainwheel and at the top of the seat-stays.
Peter.Bridge
1,586
728
The LCD stays on
3,763
The LCD stays on
Hmmm! I've run many controllers at much higher currents than what I was supposed to. I never had one overheat because of that, despite installing them in spaces where they didn't get much air. The only time I got overheating was when the motor's were too fast for their power, so they ran inefficiently and drew max current all the time.
My thinking is that there must be some other cause of your problem, like connection issue or something. Did you check inside the box and the motor connector?
Peter.Bridge
1,586
728
Yep motor connector right to the line, not checked inside the battery compartment that houses the controller. This is a 201 rpm motor i think (no load unrestricted speed on full battery 19mph)
I have had this before on completely different e-bikes with different batteries and different controllers and different motor, where on a very long steep hill at high power the assist either reduces drastically or stops completely and the controller is too hot to touch. That is hauling me (105kg) up a long, steep hill. I was a bit surpised what I had assumed was the same was happening to my niece who is much lighter, but as @Nealh mentioned, maybe I had "weakened" the mosfets by overheating when I had the bike
eta - this is happening at low speeds 5-6 mph
3,763
OK, 5-6mph is a bit slow. I'd be surprised if the motor wires coming out of the controller haven't melted. You should check them if you can.
8,736
That was my issue with the thermal cut outs, my cadence is too low going up hill and I don't have great stamina strengths to really go for it. I'm a plodder who can cover great distance though.
A 9 mosfet controller upgrade made the difference for me.
Peter.Bridge
1,586
728
So this is the new donor bike (£80) - it honestly looks like it has never been ridden
62827
@Ghost1951 @saneagle - how are you getting on with those Zoom Xtech HB-100s ? This has combined brake levers / shifters so a cable actuated hydraulic caliper would make sense. It's for my niece who is 60kg so the brakes don't have to be the most powerful
Ghost1951
2,124
944
@Peter.Bridge
I'm very happy with my new brakes on the Argos cheapo folder. They work well - much better than the original mechanical only set up. The rear one isn't that great, but the reason is the route the rear brake cable takes as it goes through the frame. There are significant bends in it, and this wastes a bit of the hand energy supplied to the lever. This is a foible of the little folder's design and not a reflection of the brake. The stopping power is way better than the original because the hydraulic system clamps onto the brake disk on both sides whereas the original system only really worked on one side of the disk. I weigh pretty much dead on 12stone 5 which is about 173 pounds, so you can work out how that will do for your niece.
They were a real bargain from Ali Express. I think they were about £25.
3,763
They're excellent - not a single adjustment since they were fitted, and they're working perfectly. Loads better than the original cable ones. I found the same as Ghost on my folder. The rear cable is actually damaged because of its route, but the other bike is brilliant.
Peter.Bridge
1,586
728
Ordered ! Went for the blue calipers , £20 for the pair including delivery and tax
Peter.Bridge
1,586
728
One thing I just noticed is that it is 3*7 gearing (so I guess it will be a freewheel). The motor hub wheel has an 8 speed cassette ! Can I use that and just use the top 7 gears of the 8 speed cassette ? Or do I need to buy a 7 speed cassette (if such things exist)
Cadence
303
221
You should be able to use the 8 speed cassette and set it up with the derailleur limit screws to just use 7 gears, or use a 7 speed cassette with a spacer ring on the inside.
3,763
Try it and see what happens. I've had mixed results when the shifter and gears didn't match.
Sturmey
699
374
68
There is normally a small difference between the 7 and 8 speed, with 7 speed 5mm c/c and 8 speed 4.8mm c/c (shimano) which can be a problem/cause unreliable indexing/having to sometimes click up twice and back once when changing .
There is a hack proposed by Shimano (rerouting of cable) in the link below but I cant say how well it works.
