Hello,
I have a TK Hansa 36Volt ebike (link). The battery is a 36V/8,5 Ah, NiMH.
Motor is a brushless 180watt 36volt disc brake hub motor.
Problem: I find it slightly to weak and I would like to have one with more torque.
I have found this motor that I think would fit my bike: disc-brake hub motor with 135mm 6-freewheel
Would it work (assuming that the controller can handle it) to use a lets say 36v 250 watt or 36v 350 watt motor with this battery? Would I be able to get full power from the motor? would I get more torque?
Thank you for your thoughts!!
Best regards,
Daniel
Best regards,
Daniel
