Repairing vengeance suntour motor with worn internal gears
ee4775
Hey guys.
I have a vengeance e spec and the planetary gears are stripped inside the rear hub. What are my options regarding replacing them.
Would a generic 36t planetary gear set fit or are they proprietary
8,533
As a unit proprietary, though one may be able to buy them as singles if the correct size and tooth count.
On Yer Bike
Mar 22, 2017
Middlesbrough
Hey guys.
These wheel's are too small & too many teeth (36t against 33t). Also, the teeth on the ones on Aliexpress are a straight cut. Whereas the ones on the Carrera's are slightly angled. I'm on with some lads who are trying to see if they can 3D print me some off. These "should" work "if", the bearing in the middle is press fitted & the wheel is not moulded round it. I can't see this being the thing. Ian @ On Yer' Bike! M'bro
