Crank Extractor extraordinaire
Yes, don't damage it with hammering, you need a crank extractor, from any good bike shop. Use this link and scroll down to the third picture and it's text to know what one looks like, and how to use it.
Crank Extractor
The last bit of the text doesn't apply of course.
Hello Philipo:
There is no way you can remove a 'well-fitted' crank from its spindle without a crank extractor - about £5 on the internet plus that unbelievable postage.
Local Bike shop would be cheaper possibly. Don't accept their offer to do it - it will cost as much and you will have no residual tool to use next time.
When you use the tool, screwing it into the crank, take care not to damage the aluminium thread. AND be certain
to REMOVE THE CRANK BOLT FROM INSIDE THE CRANK with a suitable thin cased socket. before screwing in the extractor tool.
THERE IS another way - but care is needed. DO NOT TRY TO AIM HAMMER BLOWS TO THE BACK OF THE CRANK.
Better still find a hardwood wedge, long enough to allow you to hit it with a hammer without getting near the cycle frame: better still, two the same, one on each side of the bottom bracket axle. The taper of the wedge needs to be a rather fine angle. They don't need to be driven far, just enough to 'break' the hold of the axle's taper.
Of course, replacing the crank after doing what you set out to do is accomplished by drawing up the crank/axle bolt to the right Torque (or thereabouts).
Best of luck either way
Peter
