Remove front wheel Sukara Shopper
ach45
Aug 24, 2007
Hi there
I need to replace the inner tube on the front wheel of a Sukara shopper (the valve is dodgy so tube needs replacing rather than repairing in situ). It's not my bike so I'm not really familiar with electric bikes and don't have access to the owner's manual!
Do I simply undo the bolts on either side and remove the wheel as I would do on a normal bike? I don't want to disconnect any electrics by mistake!!
Is there an online user's guide anywhere?
Many thanks for your help!
I doubt if you'd find an online guide for these Ach45, but it should be straightforward and basically as you've said.
Don't disconnect any wiring, release the V brake cable, then with the bike upside down, just remove the tube from inside the tyre on the side opposite the cable entry first. Then undo both sides of the wheel fixing, without disturbing any inside nuts etc, and lift the wheel just far enough to remove the old tube and insert the new one. Refit the wheel completely and then put the tube in and refit the tyre.
