Remote shunt watt meter
They all work. The ones with the remote shunt are not waterproof and designed for panel mount, so you have to put them in a box of some sort.
The GT one is the easiest to waterproof, but like the other non-remote shunt ones, if you want it on the handlebars, you need to modify them for a remote shunt, which means unsoldering the shunt and making your own shunt out of a short length of 14g wire (your battery cable).If you don't already have a means of measuring current, it's best to buy two so that you can use one to calibrate the other in order to get the length of wire in the shunt correct.
If you're happy with it adjacent to the battery and not waterproof, any of them are OK and easy to fit.
Sutty86
114
14
38
Skipton
Wow only just seen this I ended up buying one you recommended a while back
I'll try conjure up something wateroroof for it,
It would be nice for it to be on the handle bars but not a necessity more of a niceity.
I have space in my little tote on the back,
It would be nice to see what my battery pack is putting out
