Just finished puting the Reelights on the Twist. Some info for people.
I had to buy 2 Hub gear extensions from Reelight in order to put them on the bike as the normal fittiings are too far away from the spokes to allow the magnets the required 1-3mm distance.
Another thing is that 1-3mm gap. Anyone familiar with putting on speedometers will know how troublesome this can be. Additionally, the spoke attachments are very strong magnets, which means that when you are moving at slower speeds, the attraction of the magnets to the lights makes them touch momentarily. Note that once you get over 6mph this doesnt happen (so all you Torq riders will be ok - unless you see a hill
The flash they give off isnt the brightest, but it is quite visible from the front. From the back, with panniers on, it IS visible below the panniers, just. But how many car drivers are looking at the road?
I bought the SL120's, the version that has the standlight for 4 mins or so.
Overall, they do do what they say on the tin, but they could have made them better if they had moved the flashing parts further away from the inducers, so they could be positioned higher up on the bike.
Another idea would to have made the inducers 2-way, so that the spoke mounts also flashed as they go around the frame giving lateral flashes.
John
John
